Edit tool and scripts?
Did I miss a memo about saving images that have employed the Edit Tool and the subsequent embedded scripts? When I try to run the embedded script for an image that has used the Edit Tool PWP8 crashes. Tried making two versions of the same image, one with and one without the Edit Tool, and one crashes out (with Edit) and the other does not (without Edit).
By the way, I'm starting to really like the use of the Edit Tool, it's quite the powerhouse. Much more fine tuning control compared to the "Levels and Color" transformation in PWP7.
Re: Edit tool and scripts?
The edit tool is under construction - please do not use it.
Ah, that explains it...
