Bug fix release 24-May-20182
I have posted a new release (24-May-2018) in full installer and executable-only versions. Changes to help file and bitmap images, so full install is recommended.
Added new standard controls to most transformations to support auto/manual preview (similar to PWP 7). See help file under Using Transformations for details.
Fixed various problems with Line and Arrow tool – changed the help topic as the Alt key can no longer be used to edit control points since it now scrolls.
Fixed bugs in error reporting on color management settings mismatch warnings on loading scripts.
Fixed problem with drop shadow control not being wide enough.
Fixed bug in print causing pages to print blank (accidentally introduced 15-May).
