Bug fix release 21-May-2018
I have posted a new release (21-May-2018) in full installer and executable-only versions. No changes to help file.
Added a few more frame images (for the Frame transformation) to the Frames and Tiles Folder created by the installer.
Clone tool – fixed problem of leaving trails behind when moving cursors.
Layout transformation – fixed problem causing units to be reset every time and crash when adding a new panel in some cases.
Amount controls – on transformation startup, single amount sliders are no longer reset unless a mask image is present, in which case the mask is cleared and sliders are reset.
