Bug fix release 16-May-2018
I have posted a new release (16-May-2018) in full installer and executable-only versions. Minor edits to help file.
Fixed serious bug accidentally introduced in 14-May-2018 version causing infinite recalc loop when inserting a transformation in the middle of a branch and clicking OK.
Fixed problem causing crash when attempting to clone an empty branch.
Fixed problem with zoom out and zoom 1:1 with split screen.
Fixed problems in Clone tool with display toolbars.
Fixed problem causing error message on shutdown about converting to monitor color space.
Fixed problem causing splitters and branches to show up in image menus when selecting images.
Fixed problem causing crash in Layout when deleting panels.
Fixed problem restoring monitor curves file from script on color management settings mismatch.
Crop transformation – the button that resets the cropping rectangle to the entire image now resets the angle as well and does a zoom to fit.
Fixed problem in Bilateral Sharpen, Precise Gaussian Blur, Advanced Sharpen, Unsharp Mask causing bypass button in transformation dialog not to show input image in preview area.
