Reloading a disconnected mask
1. open an image
2. start a transformation
3. go to Amount square, choose New mask, create and apply a mask
4. go back to the transformation dialog and run Reset from the upper Settings menu -> the Amount square clears
5a. now go to Amount square, choose New mask -> the Mask dialog gets closed
or
5b. close the mask dialog using X button -> the mask gets reloaded and is reusable using the Amount Edit command
A suggestion for a kind of reset tuning:
After you Reset the dialog in step 4, you break the link to the existing mask and cannot connect it back to the transformation dialog.
Perhaps resetting the dialog might be used to reset all dialog controls except the Amount mask? Mask can always be Reset separately using the Amout mask Reset command.
