Two texture reset issues
The Reset command in the upper Setings menu
1. start Texture
2. change Tile Size to some value less then 1024 x 1024 (default)
3. dblclick either outer point on the color bar to open the Color Picker
4. Reset using the Reset command in the upper Setings menu -> PWP crashes
The Reset command in Setting next to the color bar does not close and renumber Color Pickers:
1. Shift + click to add a point (no.2) to the color bar
2. doubleclick it to open the color picker, choose a color (e.g. red)
3. doubleclick the rightmost point to open its color picker: no.3 (default white)
4. Reset the color bar using the Settings on the right -> the color bar clears, but both Color Pickers stay open unchanged:
the Color Picker no.2 stays red even though the point 2 is now the rightmost point (white),
the Color Picker no.3 is white, but there is no longer point 3
Reset command in upper Setings menu sets both Color Pickers to white, but does not close the Color Picker no.3 either.
Re: Two texture reset issues
Fixed for next release
