One or two more issues with the Mask dialog
1. Load an image
2. create a mask using the Mask dialog, do not close it
3. start a transformation, load the mask, click OK
4. dblclick the mask output to recall the mask dialog
5. close the mask dialog with the x button
6. dblclick the transformation output to recall the transformation dialog -> PWP crashes
Another scenario with reset
1. Load an image
2. create a mask using the Mask dialog, click OK
5. reset the mask from the Mask1 icon command *
* leaving the mask dialog open, closing it with x button or click OK, does not make any difference
Just out of curiosity: loading a mask into Saturation transformation takes visibly longer than into other transformations.
Re: One or two more issues with the Mask dialog
When you use Saturation with a mask, it pre-computes large lookup tables that remap every possible saturation level for every possible mask value.
I'll take a look at the mask issues. A lot of these problems arose when I fixed the mask reset bug earlier.
