Bug fix release 2-May-2018
I have posted a new release (2-May-2018) in full installer and executable-only. Minor changes to help file.
Fixed several bugs in Clone Side Branch for images with masks
Fixed several bugs in saving and opening scripts that include masks and splitters.
When saving files, the extension is now omitted. The correct extension is automatically added based on the file type when you click OK. This lets you change file type without having to edit the filename.
Fixed problem with Autorange transformation not closing its mask dialog on exit.
Zero-centered amount controls now initialize their mask to black instead of gray.
Mask Reset via the Amount control now completely removes mask. Mask Reset via the Mask Dialog settings menu just clears the mask.
Removed comment about double-clicking on mask thumbnails from the help file.
Apply buttons for Rectangle, Oval, Polygon and Spline mask tools are now grayed out when there is nothing to apply.
Fixed bug in mask causing Oval and Rectangle mask operations to be incorrectly encoded in the command line and thus not restored correctly on a double click or loading a script.
