An unwanted mask thumbail stays put
When a mask is reset using the commands in either the mask settings and/or the Amount square, its black thumbnail is removed from the Browser. But it will reappear after the output is dblclicked to recall the transformation dialog. If you then go to the Amonut square there is only the New mask command (besides Help).
I have not found a way to remove the mask thumbnail except by closing the output. No mention about it in the Help.
By the way:
There is this formulation in the Help:
"Double-clicking on a mask thumbnail brings up a Mask dialog box that lets you edit the mask."
However this is not currently so. Double-clicking on a mask thumbnail (in the browser) does nothing, but double-clicking on its output opens the transformation dialog from which the mask dialog can be open using the Amount square command Edit.
Sorry for the recent post flood.
