Bug fix release 27.5-Apr-2018
I have posted a new release (27.5-Apr-2018) in full installer and executable-only. No changes to help file.
Rotate-Mirror – the 4th and 8th bitmaps in the tool bar showing the F in various orientations were incorrect. To fix this you will have to run the full installer to re-install the bitmap files, but the bug is purely cosmetic.
Fixed problem making it impossible to drag separator line between the image browser and the image area into the image area when a probe was active.
Fixed bugs in Posterize depending on image type, palette and amount slider.
Fixed bugs (again) in many of the transformations that produce new top-level images (e.g. Stack Images, Combine Channels, Layout, etc.). They were setting the current image to an illegal value when the transformation dialog was canceled or closed.
