Stack Images - illegal images closing
scenario 1a
Highlight button pushed down
1. load one image (A) into the Browser and start Stack Images
2. load the image A into Image 1
3. go back to the Image 1 list, choose Load... and replace the image A with another image (B) from outside the browser
4. close the input image A using X
5. close the input image B using X -> the button "Close the current image and all the images that depend on it" does not work
6. click Cancel
7. click into the empty Browser -> this brings PWP down
Highlight button pushed up this scenario will not happen
scenario 1b
Highlight button pushed up or down:
repeat the scenario 1a, until the step 4
5. close the output image instead
6. click into the empty Browser -> this brings PWP down
scenario 2
load two images A and B into the Browser
make A active and load it
replace it with B
close A
close output
click to the empty Browser -> this brings PWP down
It seems that there is a dependancy between which image is active before the Dialog is open and which image is loaded or replaced:
scenario 2a
image A active when Stack Images started -> image A loaded first and replaced with B -> image A deleted -> click into empty Browser -> crash
scenario 2b
image B active when Stack Images started -> image A loaded first and replaced with B -> image A deleted -> no problem
Re: Stack Images - illegal images closing
Will look at this tomorrow.
