Bug fix release 24-Apr-2018
I have posted a new release (24-Apr-2018) in full installer and executable-only. No changes to help file.
Changed extension for workspace scripts from “.workspace script” to “.workspace” to improve the installer file associations display. The folder is still named Workspace Scripts. By a quirk of Windows the extensions both match “*.workspace”.
Stereo transformation now outputs its input image if there is no second image specified. This eliminates the error on startup. Also fixed problems with side-by-side method and negative offsets.
Image browser captions are now left justified instead of centered so the image number is always visible.
Updated a series of transformations that work on more than one image so they handle images of different types and color spaces correctly. Previously in some cases either you would get a profile mismatch warning and computation would proceed ignoring the mismatch which might combine images with different gammas or color spaces incorrectly. Now, if there is an image type or profile mismatch, both images are converted to a compatible image type and the working color space and the transformation continues using the converted images. The modified transformations are: Add Border, Difference, Composite and Filter. Also modified other transformations to require an exact type, size and profile match among all inputs. The modified transformations are Combine Channels, Stereo and Stack Images. Finally, the Compare and Frame transformations were modified to convert all inputs to 24-bit color and the working color space – the output image for these transformations is always 24-bit color.
