Bug fix release 20-Apr-2018
I have posted a new release (20-Apr-2018) in both full version and executable-only. Minor edits to help file.
Thumbnail images are now color managed.
Fixed bugs in Mask Curves tool for operations other than Add.
Fixed bug causing crash in Contour transformation for solid color monochrome background and line color
and Amount < 100%.
A left-click on a bypass button in the image browser now makes the image current. A right click on a
bypass button toggles the bypass setting without making the image current.
Embedded scripts now stored as UTF-8 strings instead on Unicode – hopefully will trigger fewer antivirus
false positives. In any case will make the files slightly smaller. The original Unicode scripts are still
supported so current files will still rebuild.
Set default zoom blur to zero so it takes less time to start up initially.
