Sharpen Window Size Memory
Make a workflow with two Sharpen widgets: e.g. first using Sharpen, second using Bilateral sharpen. Set the parameters in both. Go back to the first sharpen widget, change method to Heavy Sharpen and readjust. Go to the second sharpen widget again: the small size dialog box of the Heavy Sharpen is used in Bilateral Sharpen, cutting out some control sliders of the latter. Switching to some other sharpen method and back to Bilateral Sharpen fixes the size of the dialog box.
