Bug fix release 16-Apr-2018
I have posted a new release (16-Apr-2018) in both full version and executable-only. Added description of the new Transparent PNG transformation help file.
Stack Images: removed 15-step gray target since you can now use the Test Patterns/Simulated Q-13 to create a simulated Kodak Q-13 21-step target and print it out. Made various user interface improvements including switching to split screen so you can compare the current input image against the result image. Fixed various probe issues – the curve probe is now only active if there the current input image is present and if the Brightness Curve tab is active.
Added Transparent PNG transformation to let you create semitransparent PNG files for web sites.
Fixed crash when closing an image that was inserted between two existing images.
Fixed bug causing splitters to be incorrectly restored in script files.
