How to save Layouts with images?
I created a Layout with a background images und tried to save this for future use:
- save "Save Settings AS" just saves the layout without the used images
- Save "Save Script with " saves a script and the rebuild the result from the layout,
but the Layout cannot be reedited. The "Edit Transformation" option just opens a dialog fot replace the file.
Re: How to save Layouts with images?
I tried this and did not have a problem. After you open the saved script, if you double click on the Layout thumbnail in the image browser and it should bring back the layout with the background image. If you are using the Edit Transformation command, make sure you select the Layout image first. It sounds like the background image was selected when you selected Edit Transformation.
There are 3 ways to save:
- save with image names seemes to be ok
- save without image name prompts for files, mightbe ok
- save with image copies create a directory with the images,
but if I open the script the layout cannot be opened.
