Bug fix release 7-Apr-2018
I have posted a new release (7-Apr-2018) in both full version and executable-only. No changes to the help file.
If you move the mask dialog box from its default location just above the transformation dialog box, it no longer snaps back to the default location every time you switch mask tools.
Fixed bug in Monocolor with Amount slider < 100%.
Fixed problems with monitor curves setting and various other settings in color management dialog box. Monitor curves and other color management settings now saved in script files. If there is a mismatch of color management settings when loading a script, after warning of each mismatch, you have the option of restoring the settings in effect when the script was saved.
Fixed problems causing Mask Overlap mode for certain mask tools to fail.
