Bug fix release 3-Apr-2018
I have posted a new release (3-Apr-2018) in both full version and executable-only. The only reason to download the full version is to get the latest version of the help file which mostly has new information on Composition Guides.
As with the previous version,
If your preferences are messed up (because the location where preferences are stored has changed), run File/Preferences, re-enter your settings, and click OK.
If you get an error about missing monitor curves on startup, run File/Color Management, set Monitor Curves on Startup to something, then change it to None (unless you want to use Monitor Curves), and click OK and confirm you want to save the settings.
