Bug fix release 2-Apr-2018
I have posted a new release (2-Apr-2018) in both full version and executable-only. The only reason to download the full version is to get the latest version of the help file which mostly has new information on the new Copy transformation and Monitor Curves.
Re: Bug fix release 2-Apr-2018
Note: To get Preferences and Monitor Curves to work properly, you will have to:
1) Run File Preferences, change something, and click OK to update the preferences file
2) Run File Color Management, set Monitor Curves on Startup to something, then change it to None (unless you want to use Monitor Curves), and click OK and confirm you want to save the settings.
This will create a new preferences file in the right place and clear out any junk in the old color management settings file. Otherwise the preferences will revert to some ugly defaults and you may get Monitor Curve missing errors on startup.
