Custom crop
Custom crop
This seems odd. Open an image. Open Crop, use Arbitrary proportions and click Apply or OK, and all is fine.
Open image, Crop with Custom proportions (1920 x 1080), click Apply or OK, image is cropped in correct shape.
Open image, Crop with Custom proportions (1920 x 1080), use Resize and Resample to 1920 pixels wide @300 dpi, image is cropped and resized to 8 pixels wide. Set the above custom parameters to Default settings, when Crop is re-opened, the Resize value is changed to 08 pixels. I think "8" is the default value in inches when Resize is first checked. Perhaps "8" is hard-coded in there somewhere?
Re: Custom crop
Fixed for next release - the entered values of the size and dpi were not being read.
Re: Custom crop
Hi Jonathan,
So now images open with the correct orientation, but the crop issue persists: Custom cropped images end up with 8 pixels in width... 8.0 Alpha 31-Mar-2018.
Re: Custom crop
That last change just missed the current update and is in the next one.
Re: Custom crop
Talking about crop, will there be a possibility to define own grid (PWP7 Guidelines) in the future?
Re: Custom crop
No immediate plans, but I could do it - just out of curiosity, what would you use it to create?
Re: Custom crop
begin_object
name "Thirds - Diagonals"
line 0.0 0.0 0.6667 1.0
line 0.0 1.0 0.6667 0.0
line 0.3333 0.0 1.0 1.0
line 0.3333 1.0 1.0 0.0
end_object
Edwin Westhoff's Diagonal Method
More here and elsewhere:
http://www.diagonalmethod.info
http://diffusedthoughts.blogspot.com/20 ... ethod.html
I practically use only this metod in PWP7.
Re: Custom crop
I am working on restoring composition guides to Crop. I added a built-in Westhoff-style Diagonal Method grid option since this cannot be implemented by a simple composition guide.
Re: Custom crop
Good news, thanks
