HSV-H & HSL-H Color Curves
Ref: PWP 8 release 03-28-2018
For the Color Curves transform for channel curves HSV-H and HSL-H:
1) Curve Reset (lower right Settings button) will reset the curve to a 'diagonal' rather than its 'horizontal' when the channel is first opened.
2) The first 'shift-left click' Probe selection on the Input image results in two control points being added to the curve. Subsequent 'shift-left click' Probes result in one control point being added to the curve.
Are these actions intended?
PS... Rather unique way to make smooth Hue changes that occur about the dis-continuity at Red where it can have a value of 100% or 0%. Note: Be sure to click/read the curve Settings-Help to better understand. Also, rather startling results can occur if one is not careful. I bet Marv will enjoy some of the 'effects' that can be achieved!!!
Re: HSV-H & HSL-H Color Curves
There were several bugs causing these problems. Should be fixed for next release.
