Relief watermark
Bernard
Relief watermark
Post by Bernard »
I am sure we will continue with PWP for many years ..thanks Jonathan and Kiril.
I am trying to make a relief watermark.
I tried the emboss transformation, but no success.
Any suggestion ?
Bernard
Re: Relief watermark
Try using the embossed image (converted to 8-bit black and white if necessary) as a mask with the Brightness transformation. Then adjust the black and white sliders an equal distance to either side of the center. This will lighten or darken the image where the mask is lighter or darker than mid-level gray. The further from the center you move the sliders, the stronger the effect.
