Mat & Frame Inner Scale Factor
There is an unwanted linkage between Inner and Outer tab Scale Factors through Inner Bevel setting. When the Bevel setting on the Inner tab is set to 45 degrees, it is possible to set the Scale Factor on Inner tab independently of the Scale factor on the Outer tab. Once the Inner Bevel is changed to 60 or 90 degrees, the Inner Scale Factor jumps to the same value as is on the Outer tab and defies all attempts to drag it to a different value. It helps to refresh the Inner tab by clicking on any other tab and back again - the Inner Scale factor then appears where you tried to drag it.
To simulate it:
1. set the Inner Bevel value to 45 and Scale Factor (Texture <> Smooth) on both tabs to different values.
2. change the Inner Bevel value to 60 or 90
David
Re: Mat & Frame Inner Scale Factor
Thanks - have fixed this for the next maintenance release. It was displaying the wrong slider.
