Mat and Frame Enter key + Cancel problem
If you make a change of the Width property on the Wall tab, then hit the Enter key then select Cancel in the Warning message box then go back to the Wall tab of the Mat window and make another change, e.g. in color, Lightning type or whatever, the image is replaced with its own cropped detail. This can be undone by the Reset cropping rectangle only command, however. After that the problem does not reappear.
The same happens in the Outer tab. I have not tried the other tabs but it seems to be bound to the changes of the numeric properties that can be confirmed directly with the Enter key, which also finalizes the transformation, followed by Cancel option of the message asking whether save or not the changes made to the modified mat.
David
Re: Mat and Frame Enter key + Cancel problem
This is another problem that was caused by providing an unintentional optoin - by typing Enter you are pressing the OK button which is not normally an action you can cancel. I have removed the cancel option for the next maintenance release.
