I have finally gotten around to adding an SSL certificate to the dl-c.com and jonathansachs.me web sites. This means you can get secure access via your web browser if you link to it via https://... instead of http://...
If you have any stored links to this message board, download page, etc., please update them as necessary by adding an "s" after the "http". Everything should work the same after you make the change and will still work if you don't make the change. The only difference is that the site will display an icon indicating secure access and interactions with the web site will be encrypted.
Secure Web Access Added
Re: Secure Web Access Added
That is a good news.
Just a hint. The link to http://www.dl-c.com/DoF/ on the dl-c.com Downloads page is still http
I fixed that one and a few more. There may still be some old links embedded in pdf files.
