I have posted a new release (22-Apr-2019).
Resize: fixed problem with entering physical width in units other than inches when set to Don’t Resample.
Previous workspace no longer restored on startup if there are command line arguments.
Adjust: fixed crash when using probe to set selective color correction when editing transformation.
Mask: fixed problem causing crash in some cases after loading saved settings files that included mask settings.
Preferences: Restore workspace on startup, Save workspace on exit have been reworked. Options are now Don’t restore/save or Ask to load/save.
On startup, if Ask to restore is set, you get a new dialog box with the options: Don’t restore/Restore previous workspace/Ask for workspace to restore. If there is no previous workspace to restore, the second option is omitted.
On shutdown (or when doing a Close All Images), if Ask to save is set, you get a new dialog box with the options: Don’t save/Save by date and time/Save with current name/Ask for workspace to save. If there is no current workspace, the third option is omitted.
See the updated help file under File/Preferences for more details.
Layout: Fixed problem that could cause a crash when moving the cursor over the preview area in some cases. Also fixed problem causing panel size to be off by 1 pixel in some cases.
Bug fix release 22-Apr-2019
Re: Bug fix release 22-Apr-2019
Ref: PWP 8.0 Beta 22-Apr-2019
Thank you...
Improvement noted in this regard, particularly when loading the Gaussian Blur setting script for the Orton Effect.Mask: fixed problem causing crash in some cases after loading saved settings files that included mask settings.
Thank you...
That's where I kept seeing it, but it took a while to track down.
Upgrade of Preferences looks nice. Seems to be a thorough solution.
No more puzzling over the right script on opening PWP.
Thanks a lot.
Thanks a lot.
I'm still tweaking it a bit to get out the kinks. Next release should be a bit more predictable.
