Bug fix release 11-May-2018
I have posted a new release (11-May-2018) in full installer and executable-only. Minor changes to help file.
Reworked Adjust to hopefully avoid problems with Sharpen = 100% with mask.
Fixed several problems in Line and Arrow tool. The tool now has a new Preview button (looks like an eye, next to the arrowhead sharpness buttons) which rebuilds the output image based on all the arrows you have specified so far. This operation used to be automatic as you adjusted each arrow but could be slow for large images. There is still a problem that if a line in the overlay if less than one pixel wide, it vanishes since the overlay is drawn in XOR mode and gets drawn twice in the same location, erasing the line in the process.
Re: Bug fix release 11-May-2018
So, I see the new button, but I don't see a graphic for the "eye"...
And a request: Is it possible to add a drop shadow to the line(s)?
I see the "eye" on my system:
Picture Window Pro 8.0 Alpha 11.5-May-2018
Line and Arrow tool.jpg (270.67 KiB) Viewed 2622 times
P.S. I support your request.
Sorry, I should have mentioned, you need to do a full install to get the eye.
