Edit Transformation - dialog & script Suggestion
With a right click and selecting Edit Transformation of an image version in the Browser, the transformation dialog appears...
...would it be feasible to also 'activate' the "Image Info - Command" block so that editing could also occur here if preferred ?
180427 Halo Limit sliders-1.jpg (258.15 KiB) Viewed 2807 times
P.S. The illustration above confirms proper Halo Limit display when a script is loaded into the transform update Apr 27, 2018.
Re: Edit Transformation - dialog & script Suggestion
I is too easy to make PWP unstable by editing commands manually - I really don't want to encourage that. In fact, I was planning to remove the command display from Image Info when the program gets more stable and I don't need it for debugging any more.
You are right... ...all one would have to do is type a comma for a decimal or forget a space or miss-type a character... ...and things could go awry in a hurry. In reality, back and forth between the PWP8 Settings Folder with either Notepad or BabelPad provides more access than PWP7.
Perhaps, future thought could be given to a script exchange between users much like Photoshop 'actions' once PWP8 matures.
Yes, I was thinking along the same lines when I started developing script files.
