Thanks to Maciej Tomczak, whom many of you will recognize from his posts to this board, for suggesting the feature.
New Picture Window Release
Re: New Picture Window Release
I have fixed the problem of the clipping display not showing up if color management is disabled or the monitor profile is set to None, for the next maintenance release.
Kiril, as you mentioned Maciej's suggestion, a big thank you to you and Jonathan from us users for being so open to our suggestions!
There seems to be one more important (to me) enhancement: the mean image in Biletaral Sharpen and, by association in Brightness Curve, computes much faster now, which allows for adjusting the Radius and Threshold sliders on slower machines with much less fuss. Thanks!
p.s. What's more, it seems that the processing time is less sensitive to the radius size - it still takes longer for larger radii, but not by the same factor as before.
