Image Info with EXIF Properties
cdaniell
Post by cdaniell »
I recall with earlier versions, all I needed to do to get image EXIF data was to right click on the open photo and all would be revealed in a "display Info" window and then a sub-window.
Since Vs 7, all I can find is a Properties pull down under "Windows-Properties" which is much unhandier than a right click and worse, it has no EXIF data.
Is something wrong with my installation or has Vs 7 deleted this right click option?
CharlieD
ksinkel
Re: Image Info with EXIF Properties
Post by ksinkel »
Properties has worked as it does now for the last several releases -- i.e. you right-click on the image and select Properties. The properties dialog lists EXIF information in the left column. GPS information is at the bottom right.
In PWP 7 Properties has been further enhanced in several ways: it now incorporates the information that used to be provided in Window/Info, so all the information is in the same place. It also provides access to more editable EXIF and IPTC fields than in the past.
cdaniell
Post by cdaniell »
I guess that's my problem - You say i.e. you say 'right-click on the image and select Properties. The properties dialog lists EXIF information in the left column" However when I right click on the image, then navigate on to "Properties - After Properties, there is no EXIF selection".
This has happened on both 7.0.10 and now on 7.0.11.
Any thoughts?
CharlieD
ksinkel
Post by ksinkel »
The properties dialog is shown below. The information in the left column is EXIF information.
Kiril also wrote...
...accessed by left clicking on the "User Comments" button [lower right corner] of the Image Properties dialog illustrated above.
