Count Colors not working at 16/48bit ?
Post by Dieter Mayr »
Hello
As far I remember it worked in previous versions, but in 5.0.1.9 Window/Count Colors... is grayed out for 48 and 16 bit images.
Works fine for 24 and 8 bit images.
Re: Count Colors not working at 16/48bit ?
I found the same thing this morning (in attempting to reproduce the suggestion in the other posting).
You're right - I believe we will be reinstating this command (with a warning that it can take a very long time and use a lot of memory for large images) in the next maintenance release.
