problem : Batch processing unstoppable
Impossible to terminate batch processing.
Terminate batch processing button is grayed out.
Screen capture clip sent privately.
Workspace Scripts.zip
(34.78 KiB) Downloaded 234 times
Re: problem : Batch processing unstoppable
The video you sent was for a different workspace and does not show what happened between when you initiated the batch process and when you encountered the grayed-out button. Looking at the code, the only way the button gets grayed out should be if you click it. The workspace runs OK here when I replace the four images with files of my own and remove the Export transformations. Did you use Ctrl-Alt to cancel any of the transformations? Does it happen if there are no breakpoints?
I might have clicked the Cancel button of a transformation during a breakpoint. I also clicked the Terminate batch process button.
I never ( hardly ever ) use batch processing without breakpoints. This occurrence of the problem was with breakpoints.
