problem : raw develop strange lens correction
See screenshot of strange lens profile result.
Nikkor Z 24-200 , Nikon Z6 camera body
2025-09-03 PWP raw develop.jpg (55.38 KiB) Viewed 72690 times
Re: problem : raw develop strange lens correction
Try deleting all the files in the Lens Profiles settings (C:\Users\<user name>\AppData\Local\Picture Window Pro\Lens Profiles. This will force PWP to rebuild the lens profiles using the latest database.
jsachs wrote: September 3rd, 2025, 11:28 am Try deleting all the files in the Lens Profiles settings (C:\Users\<user name>\AppData\Local\Picture Window Pro\Lens Profiles. This will force PWP to rebuild the lens profiles using the latest database.
After deleting all files in the folder, the problem persists.
OK, please send me a copy of the raw file.
It looks OK here. Can you tell me what are the names, sizes and dates of the files in your Lens Profiles folder?
The lens profiles folder is attached
Code: Select all
    Directory: C:\Users\pierr\AppData\Local\Picture Window Pro\Lens Profiles
Mode                 LastWriteTime         Length Name
-a---          2025-09-03    14:19          57321 camera.index
-a---          2025-09-03    14:19         149442 lens.index
-a---          2025-09-03    14:19           2750 NIKKOR Z 24-200mm f_4-6.3 VR.lens profile
Lens Profiles.zip
(28.21 KiB) Downloaded 476 times
NIKKOR Z 24-200mm f_4-6.3 VR.lens profile is incorrect (the two index files look OK) -- try deleting it and doing a Raw Develop again.
jsachs wrote: September 4th, 2025, 8:13 am NIKKOR Z 24-200mm f_4-6.3 VR.lens profile is incorrect (the two index files look OK) -- try deleting it and doing a Raw Develop again.
Deleted profile. Problem persists
I tried on a different computer ( laptop ) and the same problem is reproduced.
I think the problem may have to do with the installer leaving some old files around when installing the new lens profile data. One last thing to try -- delete both the Lens Profile and the LensFun/db folders and then re-install PWP.
