An update is available to Version 8.0.503 (10-May-2025)
Add Border: when you select Oval as the shape, you now get a Roundness slider that runs continuously between elliptical and rectangular. Rounded Rectangle is remains as a slightly different option.
Updated to LibRaw 0.21.4.
Updated to LensFun 0.3.3.
Color Lookup: added support for Title metadata when loading or saving cube files. Also added Filename display (if any) and rearranged user interface.
Image Browser: adjusted the scrolling algorithm to allow room for masks and inputs of entire branch.
Update Available - Version 8.0.503
Re: Update Available - Version 8.0.503
Many thanks for this, Jonathan. I installed this version today, replacing 8.0.4something, and particularly like the controls in Warp to force horizontal or vertical movement of the grid. I use Warp a lot.
However, it shuts down very often. Sometimes when opening a new image after processing an image, it briefly presents a yellow banner saying something about downloading metadata? and then shuts down. Or else it shuts down when I complete a transformation. I mostly process 4000x3000 pixel tiffs.
The 8.0.4... version was very stable.
best wishes,
David
PC data
Edition Windows 10 Home
Version 2009
Installed on 16/03/2021
OS Build 19045.5796
Device Name Acer2018Laptop
Processor AMD Ryzen 7 2700U with Radeon Vega Mobile Gfx 2.20 GHz
Installed RAM 8.00 GB (7.65 GB usable)
Storage 238 GB SSD Micron_1100_MTFDDAV256TBN
Graphics Card AMD Radeon(TM) Vega 10 Mobile Graphics (242 MB)
Device ID A0E6B4EF-E6AE-4D05-B1BD-60E2FE9F704F
Product ID 00325-96276-33805-AAOEM
System Type 64-bit operating system, x64-based processor
Pen and touch No pen or touch input is available for this display
All updates have been installed.
Storage: 45 GB free of 237 GB
best wishes,
David
PC data
Version 2009
OS Build 19045.5796
Today I uninstalled the program, downloaded it again, and re-installed. Same behaviour as yesterday.
I'm not sure what is going on -- I don't see this here and haven't gotten other reports of general instability.
The only way I can think of to narrow this down would be for you to install a series of intermediate versions and not when it started acting up.
Let me know if this is something you are willing to try as I archive past versions regularly.
Yes, I would like try an earlier version, preferably one which has the horizontal and vertical buttons on the Warp dialog.
Here is a copy of 8.0.477 from February.
https://www.dl-c.com/Documents/Picture% ... %20477.msi
You need to uninstall the latest version first and then install 477.
Thank you. .477 works, I can load [ = "open in PWP"] a new image when PWP already holds several images. Great!
But when I load an image, I still get, for a fraction of a second, a yellow horizontal strip across the window saying "Extracting metadata from [the path of the image]"
