Extra line on Brightness Curve?
tonygamble
Post by tonygamble »
I thought I'd to go back to using the PWP Raw convert - instead of RAWTherape as it could save me time.
I used it to brighten up a problematic .dng which also had a strong yellow cast.
When I called up the Brightness Curve I found a vertical line I had never seen before. What is it telling me?
Re: Extra line on Brightness Curve?
Apparently there is a large area of pixels with the identical gold color, probably due to some kind of clipping or banding.
tonygamble
Thanks.
It was rubbish lighting so sounds logical.
