Update Available - Version 8.0.490
An update is available to Version 8.0.490 (21-Mar-2025)
Crop: added the ability to store up to four custom proportions and recall them via a drop-down menu. See the help file for details.
Re: Update Available - Version 8.0.490
An elegant solution to be sure, thank you Mr. Sachs!
However... the values added to the list via the "Edit Custom Proportions List" are not retained for future sessions. The list is empty when I close PWP and re-open the Crop transformation in a second session.
From the help file:
To make a list of custom proportions available to future Crop transformations, create the list you want and then use the Crop transformation's Settings Menu to save the settings as the defaults. This causes the custom proportions list to be initialized with your selected proportions each time a new Crop transformation is created.
Thank you.
(I read the help file, but only as far as to how to edit and add values... just one paragraph short)
Again, a nice, elegant solution.
