Image info - GPS Location geotag unrecognized by PWP however recognized by Exiftool
Greetings for the New Year !
PWP 8.0.474
File sent separately
Tagged by Exiftool with warning :
Code: Select all
Warning: [minor] File contains multi-segment EXIF - D:/Images/0 - final/2024/2024-12-23 Carriere Wellington @Arras/0Z8_0763_DxO.jpg
Image info - Location shown as N/A and buttom "Locate on Google Maps" is disabled
Whereas Exiftool shows :
Code: Select all
======== D:/Images/0 - final/2024/2024-12-23 Carriere Wellington @Arras/0Z8_0763_DxO.jpg
---- GPS ----
GPSLatitudeRef                  : North
GPSLatitude                     : 50 deg 18' 7.80"
GPSLongitudeRef                 : East
GPSLongitude                    : 2 deg 46' 30.27"
---- Composite ----
GPSLatitude                     : 50 deg 18' 7.80" N
GPSLongitude                    : 2 deg 46' 30.27" E
Re: Image info - GPS Location geotag unrecognized by PWP however recognized by Exiftool
The geotags are correctly found by Web application GeoImgr.com
https://tool.geoimgr.com/
2025-01-08 Web GeoImgr.jpg (135.4 KiB) Viewed 3930 times
I checked the file you sent and the GPS data is either missing or is not being correctly read by the Windows codec. Not much I can do as this is not a Picture Window problem. It looks like Photoshop can find the GPS info so it may be a Windows problem. Do you get the same issue with TIFF files?
The GPS data is not missing since it is recognized by exiftool, by https://pixelpeeper.com/app, and by https://tool.geoimgr.com/
It could be as you suspect a problem with Windows.
Could you change PWP such that it would retrieve GPS position using exiftool rather than from Windows or in addition to Windows ?
That's what I am working on.
