PWP Crash Related to “Set Mask Buttons” Undo/Redo
jfoster
Post by jfoster »
This one bit me a while ago. I’ve just been able to whittle down the steps necessary to reproduce the issue.
To reproduce the problem:
1. Start PWP 8.0.450.
2. Create Checkerboard Test Pattern.
3. For the Checkerboard image, use the Mask Transformation to create a new mask.
4. From within the Mask dialog box, select one of the “Set Mask Buttons” (“Mask All”, “Clear Mask”, “Set Mask to 50% Gray”, etc.).
5. Next, click on the “Undo Last Operation” button.
6. Then, click on the “Redo Last Operation” button. Note that PWP crashes.
Re: PWP Crash Related to “Set Mask Buttons” Undo/Redo
Sorry, it does not crash here.
jfoster
Post by jfoster »
Attached is a zip file of the the screen shot video of the crash. Of note, this (8.0.450) doesn't crash on my laptop. The desktop specs are:
Windows 10 Home 64
Core i7-4790s
32 gig ram
GPU - AMD R9 290x - 8 gig
The main use of the Set Mask Buttons for me is the Invert Mask.
Crash.zip
(489.57 KiB) Downloaded 72 times
Is your laptop Windows 11?
Also I noticed your mask dialog box comes up in the mask paint tool instead of the freehand lasso. This suggests that you may have at some point created a custom default mask settings file. When I did that here it did crash, and I am working on a fix.
jfoster
Post by jfoster »
The laptop is running Win 10, and I can confirm that when the Mask Default is changed to Paintbrush, the above replication steps cause a crash. Good catch on the video.
