grid lines : issue on one installation
In one PWP 8 setup, the grid lines do not follow the crop rectangle. Any idea of whay might cause this ?
2023-12-27 PWP 8.0.409 Westhoff crop guide lines.jpg (67.91 KiB) Viewed 2245 times
Re: grid lines : issue on one installation
There are global grid settings accessed from the main tool bar which apply to the entire input and output images.
There are also grid settings within the Crop transformation that apply to the crop rectangle in the input image only.
You are apparently using the first type instead of the second.
Thank you Jonathan !
I overlooked the grid selector in the crop transformation dialog box.
I had established a default grid for the crop tool since a long time ago and had forgotten about it when I used it on a different computer.
If you copy your My Documents\Picture Window Pro folder to the other computer, you will get all the same default settings, etc.
Great !
