Problem creating mask within Brightness Curve transformation
jfoster
Post by jfoster »
There seems to be an issue when creating a new mask from within the Brightness Curve transformation. When the New Mask selection is made the black Amount slider incorrectly stays at 100%.
Re: Problem creating mask within Brightness Curve transformation
The way Brightness Curve amount sliders work changed a while ago -- please check out the new help file for details.
jfoster
Post by jfoster »
Ok.
The help text linked here should probably mention this special case as well.
BrightnessXformScreenShot v1.jpg (38.88 KiB) Viewed 2631 times
Might be nice for this transformation to have two separate sliders stacked to emphasize the different behavior from “Double Sliders” elsewhere in the app.
Also, does the “Reverse Black and White Sliders” selection do anything here?
A visual cue such as two sliders instead of a double slider sounds like an interesting idea.
