erratic behavior in data entry
In the Color Picker, I tried to enter values for the RGB components.
Upon start, the values displayed are 100,0 100,0 and 100,0
I tried to enter 99,6 in the first field by using this sequence :
delete all characters
entering 9 9 comma 6
However, shortly after deleting the characters, the value 0,0 appears before I could type the new values
If I enter characters quickly, it can work. Most of the time I cannot complete the entry and the value is corrupt due to the the short time allowed.
Re: erratic behavior in data entry
You can adjust the time delay before text fields are updated in File/Preferences.
Rather than delete all the characters first, try selecting them all and then typing or double-click to select all.
While the ^C, ^V and ^X keyboard accelerators work in all edit controls, for some reason ^A does not.
In preferences, I set the text delay to 4 seconds ; however, the actual delay is much shorter, probably less than 1 second.
Thus, data entry is still erratic.
The time delay should be restarted after every keystroke. It doesn't seem the case.
I fixed this and a number of other issues for the next release. The delay was fixed at 1 sec instead of following the preferences setting. I also got tab to work as it already does is transformation dialog boxes.
