Update Available - Picture Window 8.0.245 and Slide Show Viewer 1.0.5
An update is available to Picture Window 8.0.245 and Slide Show Viewer 1.0.5 (3-Nov-2021)
Moved the Insert Snippet button from main tool bar to an Image Browser tool bar, next to Save Snippet button.
Color Management: fixed problems with Profile Mismatch for Multiple File Open.
File/Preferences: added a setting under On Script Load to warn about or ignore mismatches between the color management settings when the script was created and the current color management settings. Added the option to update color management settings for future sessions when loading a script and a color management settings mismatch is detected. This changes the current settings to match those from the script file.
Slide Show Viewer: Added transition options when advancing from one slide to the next (see the Slide Properties dialog box), added caption size options, fixed several problems and made several minor improvements.
Re: Update Available - Picture Window 8.0.245 and Slide Show Viewer 1.0.5
Seems like you cannot open Slide Show Viewer if PWP is already open. I don't think this is mentioned in the help file, but I could be wrong.
Fixed in 1.0.6
Confirmed. Thank you.
