Text Transformation Change
minolta
What is the make/model of your primary camera?: Sony Alpha a7R IIIA
Post by minolta »
Hello. I installed the 8/12/21, update. I use the text transformation regularly and noticed immediately that the background transparency slider is not working properly. Also, the default background is black when the transparency slider is set at 100%. I've uninstalled and reinstalled twice. I'm thinking a bug might have slipped in on this update. I've included a screenshot.
Screenshot .png (304.33 KiB) Viewed 2292 times
minolta
Carl R. Evans
Re: Text Transformation Change
It looks like there is a problem with 48-bit images -- it seems to work OK for other image types. Will check it out and post an update shortly.
Fixed for next release -- just uploading it now.
minolta
Post by minolta »
Thank you, Jonathan! It works like a charm!
minolta
Carl R. Evans
