An update is available to Version 8.0.200 (24-Feb-2021)
Updated to ExifTool 12.19.
Color Curves: Added to ability to load or save 1-D cube files.
Added RGB Cube to Test Pattern menu.
Added new Color/Lookup transformation that can load or save 1-D or 3-D cube files or create custom cube files based on an RGB Cube test pattern image. See updated help file or Transformations.pdf for details.
Composite, Layout, Repeat, Stack Images: fixed problem setting display to output image when an input other than the base image was selected.
Update Available - Version 8.0.200
Re: Update Available - Version 8.0.200
Many thanks for the LUT-file support. Some first tests look promising.
The *.cube-files work with my slideshow-program.
Good -- I had no way to test if they worked with other programs.
