Update Available - Version 8.0.182
An update is available to Version 8.0.182 (14-Dec-2020)
Gradient transformations: switching display mode (input/output/side-by-side) now closes all color pickers. This guarantees the overlay on the input image remains displayed.
Closing images: if all the images being closed are bypassed (and none is a splitter or side branch) the remaining images are no longer recalculated since they are unchanged.
Status messages now have a yellow background to make them stand out.
Add Favorites button to main tool bar which brings up a Favorites dialog box. The Favorites dialog box displays a list of commonly used transformations you can customize with your personal favorites. Similar to Quick Pick but the selection is limited to the transformations you configure. To get the favorites bitmap for the main tool bar, you need to do a full install. You can also get to the Favorites dialog box by typing “/” when no other dialog box is active.
