Just a minor suggestion:
The default size of a New Image is 100 x 100 pixel, when no other image is active.
With todays screen resolutions this is very small, on my system with a res of 1600 x 900 it's hard to find a point in the title bar between the icons to move the window.
Would it be possible to make the default to maybe 200 or 300 pixel square (maybe 1 inch at the default DPI) ?
Or maybe even to set a default in preferences ?
Default size of New Image
Re: Default size of New Image
Dieter,
Thank you for the suggestion.
One way to manage the default size is to select an image that is near the sixe you want and then click on File/New/Image. The default is then set to the size of the selected image.
