Fuji X20 .RAF Conversion Crashes PWP7 Beta
Posted: May 26th, 2013, 6:07 pm
by frankpix
The subject says it all.
When I open a Raw file (.raf) produced by a Fuji X20, PWP7 begins the raw conversion, the "Loading Raw Image" progress bar gets all the way to the right, the program seems to freeze for about 5-10 seconds and then it crashes with the message: Picture Window Pro/32 7.0.8 has encountered a problem and needs to close..."
Would you like me to send a .raf file that you can experiment with?
Frank
Re: Fuji X20 .RAF Conversion Crashes PWP7 Beta
Posted: May 27th, 2013, 1:47 am
by Dieter Mayr
Frank, PWP uses dcraw for RAW-conversion, and according to the dcraw website http://www.cybercom.net/~dcoffin/dcraw/ the X20 is not supported yet (dcraw version 9.17)
You can check the dcraw version used in PWP in Help - About Picture Window Pro.
Posted: May 27th, 2013, 9:35 am
by frankpix
Thank you Dieter!
I thought the X20 was going to be supported in dcraw 9.16, but I can see it's not supported yet. (I knew about that cybercom page but I never scrolled to the bottom.)
I suspect software vendors may be having some trouble with demosaicing of the X-Trans sensor. At this point Raw conversion support for the X-Trans is a bit thin. I even tried the latest DNG Converter, which is listed as supporting the X20, but no joy.
Frank
