Can the widget order in an existing workflow be changed, or at least can an existing widget be copied and pasted? I'd quite like to use existing widgets with their associated parameter sets but would prefer not to have to start from scratch and re-build them in a different order. Nothing in the documentation seems to suggest that they can.
Ian
Workflow order
Re: Workflow order
Workflow does not currently support rearrangement of widgets, so you would have to delete a widget and insert and reset the widget somewhere else to change the order. However, in most cases the order of widget operations does not matter, so hopefully this will not arise too frequently.
- What is the make/model of your primary camera?: GH2, G80, (Fuji XT-1)
Re: Workflow order
OK thanks Kiril; as I thought. May be an ability to 'drag n drop' widgets might be nice to have at some point.
Ian
Ian
