Problems opening images
Posted: September 24th, 2011, 6:20 pm
Hello,
I hope someone can suggest a cause and easy fix for an issue that has recently developed.
Up until fairly recently (within two/three weeks) I have been running PWP (version 5.0) with no problems encountered. However, I have recently noticed that when opening an image (16 bit TIFF), the image will not open and I get an "Unable to open TIFF file" message. When I first noticed this issue, the occurrence was fairly rare and if I pressed the "OK" button and tried again, the image opened. More recently, however, the problem is becoming more frequent and it sometimes takes 6 - 7 tries before the image finally opens, if at all. Occasionally, when I unsuccessfully try to open by double-clicking, I can drag the thumbnail onto the working area and open with success or if initially trying the drag method and it won't open, I can usually double-click with success. Sometimes, the only resolution is to close the program and re-open, where it usually operates fine (for awhile anyway). The problem occurs at anytime (after just opening the program or after the program is open for some time) and sometimes I can use the program for hours with no issues at all and sometimes I have to close and re-open the program for it to work.
Since initially purchasing and downloading version 5.0, I have changed nothing with my computer and am able to open the same images with two other programs with absolutely no problem. I expect, as a result, the problem is PWP specific.
I was hoping to ignore this problem until the next version release, but the issue seems to be getting more frequent and I am also starting to encounter a "Cannot open file while current operation is in progress" even when the program is freshly opened and no operation has been invoked.
I'm hoping the resolution is easy and does not involve uninstalling and re-installing PWP as this particular computer is not hooked to the net and this operation becomes a bit of a task.
Thanks in advance for any suggestions.
