Update Available - Version 8.0.555
Posted: March 12th, 2026, 10:27 am
An update is available to Version 8.0.555 (12-Mar-2026)
Added an auto/manual recalc button to the top of the main window (at the far right). This lets you postpone propagation of changes to transformations, which can save time if you are working with large images or transformations that are slow and want to make multiple changes without having to recalculate after each one. When auto recalc is turned off, thumbnails of transformations that require recalculation are displayed with a pink caption background. Turning auto recalc back on recalculates all transformations that require it. A warning is issued if you try to save an image or script with auto recalc turned off. If auto recalc is disabled, starting a batch operation turns it back on during the batch process and then back off again when it completes.
Monitor/Printer Curves: Clicking and dragging on an image highlights the parts of the curve corresponding to the brightness and color of the image.
Stretch: fixed some problems with dragging control lines past the input image boundary. Switched the horizontal/vertical selector from a drop-down menu to a tool bar at the top of the dialog box. Two new bitmaps require a full install.
Notecard: added two new card layouts for 5x5 square images. These are designed to fit 5.75x5.75 inch envelopes.
Mask: fixed problem with resetting the initial image not graying out the undo button.
